rfj62
Hey guys, I was looking for some advice on replacing the front
end plate gasket, since I didn't do it right the first time.
To make a long story short I got a new short block from Toyota
for my '89 FJ62 because of some internal damage. I took the old
engine out set it next to the new engine and started to move what i
could over, transmission adapter, water pump, etc. While I was doing
this I got the head magna-fluxed and cleaned up. I put the frond end
together, new canshaft, new camshaft timing gear, all new gaskets
from Toyota, the works. Got everything together so then I primed the
engine by spinning the oil pump as fast as possible with an electric
drill, oil leaking out of the front, not a good sign. :whoops: I took it
apart again and believe that I mis-torqued either the front end plate
bolts or the timing cover gasket because of the different torque
specs.
Back to Toyota to get some a new frongt end plate gasket and
timing cover gasket. Pull out the remove the rocker assemble,
lifters, rods and camshaft, replace the gasket RTV it and put
everthing back together very carefully following the Toyota FSM,
double check the torque setting twice before I tightened them even
cross referencing with the Haynes manual. Prime the motor again and
all is well, so I think. Put the motor back in fires right up after
the fuel got back up to the engine. Running good until I notice the
leak coming from the front end, you've got to be kidding I can't
believe this!!
It was hard to tell where the leak was coming from but I
believed that I narrowed it down to the top right side of the timing
cover/end plate. I tightened the timing cover a little tighter and
the leak has realy slowed down, but not enough to not leave a little
reminder on the pavement that I was there.
So I got another front end plate and timing cover gasket and
will try again this weekend. I am going to remove the radiator,
grill and everything else on the front end thats in my way and try
and remove the camshaft while the engine is in the truck. Does
anyone know if I am doing something wrong? Any advice on removing the cam while the engine is still in the truck? How much sealant should I put on the gaskets? This time I got the Toyota sealant.
Any help is greatly appreciated. Jeff
specs.
believe this!!
