!!!!!!I Updated with my solution!!!!!
The background:
I have a 71 cruiser that I had upgraded the stock axles on and while doing that, I did an SOA, spring flip, and shackle reversal. I rotated the pinion to 13-14 degrees, redid the caster to + 4-6 and done. I did new hangers by ruffstuff, etc. etc.
So now I shortened a front 60 to 64.5" and took out the stockers but b/c I flipped the front springs (center pin foward) and did the SR, my 60's pinion barely hits level 0 degrees under load (unweighted the pinion points down) even though the GM 60 has a factory pinion angle of 10 deg IIRC. I don't really have the time nor do I want to 3 or 4 link the front. I want to keep it on leaves. Solutions.......
I know that I can use caster shims, but I don't really want to use 12 degree shims
I can shim 4-8 degrees and live with it
I can redrill and flip the spring back to stock and lose 4" wheelbase (not sure how much it will help)
I can put the shackles back on the front (but I like he SR and spent time and money doing it)
What do you guys think? Any other suggestions?
The background:
