You guys are talking about some of my "Bugs" I'm chasing right now. Squerly on the highway.
first thing I considered when using a radius arm is during articulation the axel housing will be "rung" like you would a wet dish towel. The further the upper mounts are from the lowers the more binding. I used the same mounting seperation as the JK (7" or 8" I think). I used the new ourglass rubber bushings at first but they allowed way to much movement. I ended up using the OE XJ rubber inserts and rings for all three points on each arm as well as the rear arms. Way better! And yes fully adjustable upper arms for correct caster placment.
A freind of a friend used himes on all points of his radius arms and continully broke mounting brakets. Some flex has to be there.
Also some binding is good for stability. I didn't go into this project thinking that but now is different.
At all 6 points of connection to the frame I used Rubicons super flex ball joint (greesable, rebuildable, adjustable).
I'm running front and rear sway bars and its not quite perfect but close. I want it perfect! Perfect in my mind is to have my wife drive it and NOT say "WTH?"
I found out recently that I was charging/adjusting my coilovers wrong. My pressure range is from 150-250 and I was charing while the truck had static load. Doh! Not getting the damping I need to keep the truck from leaning so badly.
My caster is set at 5 1/2 degrees right now. Looking forward to getting home this weekend and pressure up!
Jodo
Jodo
