Background,
I installed a Ironman 4" lift onto my truck a few weeks ago, and had to put in extended brake hoses. the kit came with the wrong front passenger side brake hose so I ordered a Man-a-Fre hose to install, so the two front line are of different manufactures. When IO bled the brakes I noticed that the fluid was horrible and planned on having it completely flushed that week. I drove the truck for a few days (approx 120 miles) with no problems.
Then one night driving I noticed a severe lack of power and came to a stop. When I put the truck back into drive it did not move. I repeatedly tried to go from park-reverse-park-drive multiple times but it would not move. I left the truck at the parking lot and the next morning when i returned I put it into drive and it moved no problem. I drove it around that morning and afternoon with no problems.
That night they locked up again. I touched both front rotors and they were extremely hot. so after 10-15min of messing with the park-reverse-park-drive, and banging the calipers with a wrench to no avail, I put the truck into low and the truck moved. So i removed the ABS fuse and was able to drive home no problem.
the next day I was driving to a brake shop to have the lines flushed and have the ABS system looked at becasue I assumed it was the ABS that was the problem blocking the pressure from being released to the calipers and the brakes locked up again (with the ABS off). I called a tow truck to come tow the truck to the shop and after 15min I tryed drive and it worked. I was able to drive myself to the brake shop no problem.
The shop flushed the whole brake system, and replaced the brake master cylinder. the problem seemed to be fixed for another day, then the following day they locked up again.
It is currently at the shop (as I am at work for a few weeks) and the shop is trying to see what could be wrong.
I read a lot on here about calipers sticking, but this issue i have cant be that becasue they both stick at the same times. and that would be too coincidental for them to be the problem.
So the Brake master cylinder has been replaced.
I thought maybe the extended brake lines but they are of completely different manufactures. so that also would be too coincidental.
I have a few friends that are thinking it may be the brake booster.. your thoughts?
Any thoughts and ideas are greatly appreciated!!!
