NorCalBorn
- Joined
- Aug 31, 2008
- Threads
- 102
- Messages
- 1,856
I've been fighting with my front rotors off and on for the past two years, where I end up getting some pulsating and clicking happening about 11-12 months after every repair.
I usually only see about 1/1000 of runout on the rotors, so the first time left them alone. The second time I went ahead and turned them. The third time I got fed up and warrantied the rotors for a set of Brembo rotors and Akebono pads. I replaced the hardware also, and here's where the kicker comes in..
I always prefer the Disc Brake Quiet that cures over the new lube/grease junk. Simply because I started to realize it might be a part of the problem, as I have worked on this system on easily over 100 trucks and 4Runners over the years, and this is the worst and most frustration I have had, and it is because it is my vehicle.
So after talking with someone about this stuff last night, I decided to look at things all over again, including checking the runout on not just the rotors, but also the hub as maybe the back face is off and slightly warping the rotor upon torque load. We used a dynamic check and a dial indicator set, all was good.
Hmmm, lemme check the pads and pistons, all good...aaaaarrrggghhh, why me!!!
Get this, I decide to go ahead and throw it back together and let the person I talked with do a look over in a week when he has the space to bring it in.
I grab some brake clean and clean off the hardware to put some shine on them to see if the pads are sticking and guess what I finally find?
The stupid anti-squeal lube/grease crap doesn't keep the pads attatched to the pistons so they'll retract fully and the hole that the locating pins slide through to hold the pads in have worn notches into the pins, leaving a slight edge to them making the pads catch even more, dramatically adding to the issue. In other words, where the pads move on the pin, the pad backing plate is wearing into the pins because of the freeplay instead of sticking to the pistons and fully retracting.
I went ahead and took the pins and cleaned and sanded the ledges off, coating them in anti-seize until I can pick up a new set later this week, and am also ordering some more brake clean so I can remove all the completely worthless anti-squeal lube junk.
I thought to share this with all here because I realize we all face these kind of things with our vehicles thinking all is bad and forgetting two simple things.
Check the basics before getting all the way into things.
Sometimes the newer stuff isn't always better.
*Ultimately I attribute this to the fact that the last two times I used the anti-squeal lube junk, I relaced the hardware, but didn't think to look at the locating pins for odd or excessive wear, lesson learned.
