Hi:
On my way to Surf and Turf I really noticed that my brakes were not working well, I had a few folks at SNT look and them and I thought I would post Up here and get some advice for my 1985 FJ60 Expo Build
Symptom:
I cannot lock up my brakes if I wanted to and most of the braking is comming form the rear. The brake pedal goes down and stops hard, when I push harder I only feel the rear brakes
1) Emergency brake stops at 5-6 clicks, I do not think it is dragging but I have to check one I get home.
2) Front pads are not shiny, I cannot tell what type of pads they are (non metalic etc), when expanded the calipers contract ok
3) The rotor surface has little fissures in it, very similar to the look of a flywheel that needs resurfacing. Does that mean that the rotor got too hot at some point???
4) I am loaded to the gills with gear, custom cabinets etc and do not plan to lighten the load much so whatever mods I do will be done with the extra weight in mind
5) I am Running 33's
6) I do not have an LSPV
7) I did pump the brakes w/ the motor off and then started the motor w/ foot on brake and the pedal did move an inch or so.
Any Ideas, I was thinking about getting the Man-A-Fre sloted rotors and semi metalic pads. Or something similar that Marlin Crawler might cook - up for me.
Thanks
Mark
Symptom:
Thanks
Mark
