What is your altitude? As you tune the carb the vacuum should raise but there may be a vacuum leak somewhere.
Just to clarify, you are talking about the white multi-port VCV that is under the passenger side of the air cleaner correct?!I had a bad VCV that leaked vacuum internally. there was no way to notice it other than knowing my vacuum was low(about 14.5) and I could not locate a leak ANYWHERE. I finally started capping off vacuum sinks one by one till I got to the VCV and bypassed it and all of a sudden I had 19" of vacuum and a steady idle- albeit with a fat mixture from trying to compensate...readjusted and on I went. Look at your dizzy vent VCV...if that tests OK go to the next vacuum sink and bypass it. unbypass if it has no effect and move on...
But that is saying 16 inHg at sea level would not be good. If he is less than say 4k' above sea level then there is a vacuum leak somewhere. But again he hasn't done any timing/tuning so it SHOULD go up.16"s is ok vacuum for a very big cam...not so good for a stocker...keep looking for vacuum leaks...have you tried the propane trick?
Thanks for posting the chart - I always wondered how well my stock '76 FJ40 (~64,000 original miles) was doing vacuum-wise after a complete tune-up and adjusting everything by the book. It purrs like a kitten at idle, and has pretty good power, but I can't get any better than 14 inHg. Now I feel a little better: 20 - (29.92 - 22.88) = 12.96 (my driveway is right at 7,240 feet). I never took the time to check for vacuum leaks using carb cleaner or propane - now that I'm curious I might give it a shot tomorrow (no snow on the ground and ~47*F for a high).Use this chart to de-rate vacuum readings according to altitude. Use the difference between Maximum Value Attainable and your altitude. Subtract that number from 20.
Example: At 2000 ft, the vacuum drop is 2.12 inHg. 20-2.12=17.8 inHg vacuum on a perky engine
That's a pretty sanitary engine bay. Compared to some cruisers, it's not covered in mud & rust & PS oil. Keep up the good work!
Minor notes:
The rubber carb to air cleaner seal actually snaps into the neck of the air cleaner, then the AC lid is carefully dropped onto the carb.
Because the ICS is permanently grounded to a carb screw, there is no need for vacuum switch. Either rewire ICS back to stock config (ignition hot & computer ground), or remove vac switch & engine computer.
Where is the volt regulator on the alt? Looks like an old external regulated type.
Sweet! Looks like I got a mini project while it is freezing out... Wonder if this has something to do with the sudden fuel consumption problem I am having.Yes, to waste even more gas than stock, remove the vac sensor switch & computer, disabling decel fuel cutoff.
