I've got the 3/4 ones with the 7/8" pin.
That's my vote (not sure what size that implies), but would like to carry only a single set of shackles that I can use front and rear...
These are designed to use 3/4" shackles (7/8" pin) - that part of the design is not changing. I don't know what size shackles the slee bumper uses.
The only question here is how tight the tolerance is for the hole that the pin fits into. We can keep it 1" as was posted in the original design or we can tighten it up so it's a nicer fit (say .89 or .9 inch diameter).
Just build them already!
I don't have a strong opinion on the tolerance for the hole. I'm happy to go with what ever you land on. ...my sense is that at least in my use these will not be used everyday, and thus my concerns about wear, etc. are minimal. Just very excited to get something robust to mount a shackle on up-front.
Thanks again!
Tighter you make the tolerance the more difficult it may be to insert the shackle pin when coated with mud. Why mess with something that works now? Just build them already!
My vote would be for the tighter tolerance as well. A 0.900" bore will allow for minor variations in 3/4" shackle pin dimensions as well as allow functionality in dirty conditions.
How about 15/16 hole size giving 1/16 clearance - that should be better fit and way more than enough space to rotate freely? Still tighter clearance than 1/8".
According to this: https://forum.ih8mud.com/100-series-cruisers/224920-what-size-shackles-do-i-need.html#post3376461 the 1/16" clearance is what spressomon had planned for the larger shackle design anyway (1 1/16" hole for 1" pin).
I just submitted the change and will follow up with him tomorrow. Hopefully this is a happy medium - meets the request some buyers had to tighten the clearance, and also addresses any safety concerns or powder coat thickness/dirt/grime/snow concerns by not being too tight.
Thanks for the input guys. I think this is it for changes.
Thanks!
To assuage any concerns participants in the group buy may have:
1) at least some shackles use < .875" as the actual pin diameter. For example one participant measured his green pin shackle (by van beest) at .866". Of course it's possible that due to tolerances some may end up tad > .875 I can't say. But if some manufacturers intentionally make the tad smaller than .875 that gives even more clearance.
2) the hole can always be bored out more if needed.
3) within a reasonable time frame (2 weeks?) after receipt of the shackles, if anyone has an issue with a 3/4" (7/8" pin) where the pin fit is too tight due to the hole (and not caked paint drips or something that can easily be sanded off or debris that can be cleaned out with a finger), I'll work it out with them.
The goal is for everyone to have safe, solid recovery points - enough clearance not to bind, tight enough not to side load.
