For Sale @ High Desert Cruisers (17 Viewers)
the good stuff always sells quick
another 8274
Warn Winch
Here is another one. Its been posted since noon today
jstncse said:
Warn Winch
The price is just not as inviting as that last one
'96 FZJ80 w/ Diff Lock
A friend of a friend is looking to get rid of her '96 FZJ80. I only have a small amount of info but here's what I have:
130K miles
Has the DIFF LOCK switch
Engine 'rebuilt' a year ago
Needs some work (Brake booster, O2 sensors, 'some hoses')
Asking $7,300
PM if you want contact info for the owner.
Sold the 45 crawler today. :crybaby:
I still have some stuff in the garage I want to move:
Steve, call me re the elocker rear
Shawn, I have something for you
3 fj40 rims, no hubcaps, all are for disk brakes IIRC. I has tire attached. Free
2 fj60 rims, both with tires attached. Free
1991 fj80 front axle, complete less tie rod, and driveshaft (not DC) $150 obo
tan leather 3rd row 80 seats, no hinges, no mounts. Free
DC shafts. I think I have 1 fj60 with dented tube and 2 or 3 79-85 minitruck, all probably need rebuilt, some better than others. $20 ea.
a/c brackets/pulleys to mount a york on an F motor $20
I may also have one for a 2F $20
gear redux starter from fj60 $20
Good morning,
I could use two of the rims... two of mine are slightly bent.
Thanks,
Guy
Ah, yes, the 40 rims!
A trip is possible... although I don't have room for the axle.
Forgot, I also have 2 2F flywheels and 2 4.11 thirds (cores) for free.
one airtank from an airbrake rig, probably 3 gallons or so with several threaded holes. I have no idea the internal condition. $20
fj40 rear step (2, slightly bent) free
I could also use the two 4.11 thirds (cores) and one of the fj40 rear steps
no worries, I think Steve wants to see it first. Hopefully I can pawn off more of this to HDC and someone can make a group run. :)
Too much has come up lately so can't afford the rear axle. Thanks though.
jericho said:
The time has come to sell the 60... Craigslist Ad. Discounted price to any HDC member.
I am also selling all the parts necessary for a 2FE conversion - $400. This includes all the bits from a 92 3FE ie. computer wiring harness, head, manifolds, fj62 air filter box, FJ 62 fuel tank ect... PM for details
Throttle cable/gas pedal set - $25
FJ62 dash handle gray - $20
After market FJ60 series radiator $75
2 FJ62 diffs 4.11 gears! Came out of the front axles $75 each
3FE starter $30
3FE power steering pump $20
3FE alternator - $20
3FE air pump - $15
Good deal indeed Jared....
Bump
more parts:
80 series MAF/4+ control arm drop brackets 3" drop $100
found another 4.11 diff core FREE
double diaphragm brake booster from '77 fj40 needs rebuild FREE
minitruck t-case parts leftover from Marlin build--case and gears left after reduction box removed. FREE
tcase output flange from fj60 FREE
thinking about selling my Slee OBA setup for 80 includes compressor, bracket, pulley, belt, air tank, manifold with gauges and regulator $250
