Flywheel Torque spec?
Roseville, CA
I can't seem to find it anywhere, could someone please tell me?
Also....
I've found a lot of different opinions on whether you use RTV or locktite on the flywheel bolts. Should I use locktite on the threads and RTV on the bolt head or no RTV just locktite on the threads or just RTV on the threads.:doh: That's not confusing:confused:
TIA-
Flywheel torque is 47ft/lbs. according to the manual. I set my wrench to 50, since it is a grade Unobtanium, ultra fine thread bolt, and I've seen a few of them lose clamp load and allow the flywheel to tear up the tail of the crank.
I recommend Permatex #1 hardening, on the bolt threads as a sealer and as a mild loctiter. Manual says #2, but I like the permanence of #1.
Thanks-
