Howdy folks. My Fj60 seems to be losing charge when under load. It starts up and idles and drives perfectly until I have to use the headlights and wipers at the same time. If I am in gear and driving with lights and wipers then it is perfect, but when I come to a stop sign or a red light or try to cruise in neutral down a hill or something, the cruiser will die... charge light comes on and it just dies. No problem restarting, but it's dangerous and a pain.
If both wipers and lights aren't draining the battery then there are no problems at all. If my blinker is on then it is even worse and the truck dies even faster. I have to use the manual choke to get the revs up before I stop if I am using anything electrical.
When my blinker is on the voltage needle goes up and down quite a bit and after 4-5 blinks, it is at half and the truck dies.
Alternator rebuild you think? I already changed my IC regulator and swapped batteries and there was no improvement.
