- Thread starter
- #101
The 1HD radiator was used because the fittings are slightly different for the intake and outlet. The fan shroud from the 1HD was also used, so that it would line up with the fan. You could use the original gas radiator, but would have to figure out the hoses and may have issues fitting the fan shroud.
Heater hoses... The ones from the motor to the inlet valve and the return hose from the fire wall to the motor are from the diesel. The rest of the hoses are the original gasser ones.
Power steering lines... Used transmission fluid hose for the L.P. side. On the H.P. side the gasser line was used. It had to be modified a little bit.
See my sig line.
