For Sale FJ80 Headlights, Tailights, Dome Lights, Corner Lights, markers
Do you have an a/c receiver dryer?
yes. R134, R12, or Nitrogen?
May I have the year of your Cruiser. That will help. Often on the front frame crossmember (radiator brace) there will be a sticker saying R134,
if so, there is the answer. May I have the outside diameter of the caps on the compressor that protect the fill line. There should be two plastic caps that thread on. If yours is a 1993 or newer, it is probably R134. If 91-92 it is most likely R12. If it is a 96 or newer, I can check to find out. I have the part from a 1994, and from a 1997. They were both blowing cold air when I removed the engines.
Mine is a 94. Im in Texas right now but will check tomorrow & let you know.
Thanks!
And while Im thinking-do you have the piece that sits behind the hood/under the wipers? Mine is bent...
Yes, in green, white, ruby red, and root beer bronze. I have the drier from a 1994. It also looks just like your picture.
The drier is $25, the metal cowl piece with vent holes for under the wipers is $30, shipping has not been determined. If you have a FEDEX or UPS account let me know, other wise I will shop for shipping. otherwise i need your zip code
I need your zip code to calculate shipping.
And your color for the cowl (I will bet it is green).
see your private message
I have dome lights in brown.
I just started parting out another one and have a full set of lights as listed all over again.
I do not have headlights for 1997, Sorry
Pasadena area. 8/06/17 EVERYTHING IS AGAIN AVAILABLE
Shipping extra at lowest cost possible.
Headlights are 1991 -1994
Tailights are 91-97 -
Front corner Amber
Rear Quarter panel marker lights 91-97
Dome Lights Brown only 91-96
Turn signal lights 91- 97
Hi Paul, can you indicate price for left and right headlight assemblies?
Shipping to Rochester, MN 55906.
Thanks,
Dan
Yes, see your private message.
