FJ80/FZJ80 Power Antenna Assembly
This unit is suitable for parts or as a rebuild able unit.
This early style antenna assembly is suitable for units that use the smooth type nylon cable vs. the later units that use the toothed nylon cable.
This does not have the nylon cable nor the nylon gears. It does have a working motor and the exterior plastic housing, aluminum mast housing and bracket are all in great condition.
$25.00 and free FedEx ground shipping to the lower 48.
Add $2.00 for Paypal payment.
still available?
Hey is this still available. I've got a working power antenna motor, but a friend cut the coaxial cable too short and it can't be spliced. As far as I can tell it is now useless. So I have the parts that you described as missing Let me know. Thanks.
Is this the 97 one with the teeth on the antenna mast or is it the pre 97 with the coil mast system?
That would be info in the first post.
:grinpimp:
