Starting the madness . . .
August of 1992 FJ80, 220k miles, grinding front diff won't go unless locked:
Our Land Cruiser has changed its function from "indestructible family vehicle" to "spare, project ridden, toy"
Current (1st major) project:
Bought OME suspension kit from man-e-fre (2" med-heavy 80DH kit). I don't see a problem with this for I've done this type of stuff on old Pontiacs.
Also bought Knuckle rebuild kit with bearings - not too worried about this.
Also bought Front differential bearing kit - - not too worried about this.
But, when I get into the differential, I'm worried about finding broke/torn up teeth or just plain worn out.
Looking in the service manual, it seems a lot of work to fix the differential.
With the vehicle grinding and not moving unless the differentials are locked, will I most likely run into a tore up front diff?
Assuming YES the front diff is tore up, should I try to rebuild it or get a new one? Do they sell new ones?
One last question, since I'm upgrading the suspension, I figure the entire front axle assembly will be close to off the car. So I intend on disconnecting the brake lines and bringing the whole thing inside to do the work (rebuilding the knuckles and front diff-bearings and gaskets). Good idea or too much work to get it off?
