OK GUYS HERE YA GO...
1. buy a toyota replacement mast...no measuring or anything...perfect replacement to simply instal, it comes with mast and new spindle, got mine from cool cruisers 48$
2.remove 3 screws from washer resevoir, then disconnect hose and electrical connections from pump on resev, simply to get this stuff out of your way
3.On antenna now disconnct black antenna cord going to radio located on the silver tube concealing antenn.
loosen bolt holding antenna to fender inside engine compartment. then start tapping counter clockwise with a small flat screwdrvr the silver bolt on the exterior of vehicle where antenna comes out. this will allow the anten to come loose. Now fully remove the bolt inside engine compartment holding the antenn to fender wall. now allow antenn to lower down inside fender and pull it out to easily remove electricle connetion and ground wire.
4. Now antenn is completely out. twist and pull up(bayonet style lock)off the tube concealing antenn. Remove nut holding on gold cover and 2 lower bolts holding on the mounting braket. The silver spindle is now revealed. Remove 4 gold screws to release from white sprocket and you can cut old white nylon cord to remove old antenna.
5. Feed new antenna threw silver tube from bottom and extend it all the way out. Now attach white nylon cord to new spindle and tap down where cord feeds threw little sleave part (refer to old spindle if neccessary) to to lock in place. replce back on white sprocket with 4 new screws provided. Replace gold cap and replace mounting braket to gold cap.
6. now temp hook up elect conn to antenn to test and lower down antenna which will wind your new antenn for you...as stated in previous post MUCH EASIER!!
7. if all good you're ready to re-instal to your rig. replace grounding wire and electricle conection first. Its easier to do now. Then slip antenn dwn into fender and poke antenna out threw hole up top. Now replace the exterior molding and silver tapping bolt(where the antenn comes out of vehicle when in use), but DO NOT TIGHTEN. now attach antenna to fender by replacing bolt to mounting braket inside engine compart, BUT DO NOT TIGHTEN. Now tighten your silver tapping nut on the exterior of vehicle and then tighten mounting bolt braket. Now reconnect black antenna cord going to radio and tape down just to hold in place like factory did. TEST ANTENNA up down ability and radio reception clarity.
8.If all good replace washer resvoir and you're done.
I hope my several hours of cussin and figuring this out helps shave your project down to about 1 hour...good luck fellas! Its pretty easy once you know the tricks! If pics dont show once I post here is a direct link to my photo album:
Snapfish: Share:Registration
