Hi All,
Slowly working through my complete frame-off rebuild/restoration of my '89 FJ62, and we got to the point today where it was time to fire the engine off. Well, with a bit of starting fluid, it came to life and idled okay for a little while. But after a couple of minutes it started breaking up and running really rough. Eventually it died. I could get it to restart and run for a bit - then it'd die. Each time it'd run for less and less time before it died. Eventually it got to the point where when you turned the key to start, it'd run for about half a second and die.
I'll give a break down of things I tried/observed:
- There was no check engine light while it was running
- Unplugging the engine coolant temp sensor or TPS made no difference in the dying behavior
- Shooting a bunch of carb cleaner down the intake would make it start and run longer - so it's not a spark issue (at least it seems like it's not)
- Brand new fuel pump
- Brand new fuel lines
- Brand new fuel filter
- I unplugged the cold start injector, and the start-die behavior did not change. So it's not like it's just running off the cold-start shot.
- When it was running, it didn't really respond to throttle. It'd just sort of hesitate and cut out.
Before we took everything to pieces last year, we did very the engine did start and ran. Everything has been sitting since. When we took it apart, we did not disconnect any wires off the engine - we just unplugged the harness from the PCM and draped it over the engine.
Any ideas or trouble shooting tips?
