FJ60 Wiring Diagram anyone? (1 Viewer)
Texas
Does anyone out there have a pdf file of the wiring diagram for an FJ60 ? I need to get FSM's...
I've lost power to my A/C compressor and blower motor, checked all the obvious stuff. Fuse, relay for blower. Don't know if I have a bad switch on the dash or what...
I would ask on the 3FE list if you don't get a quick response. The guys on the yahoo group might have it readily available.
Check your circut breaker. It will be under the dash behind the fuse panel if it is an early model or in the fuse box if its a later model. Take a paper clip and push it into the little hole on the cover of the breaker and it should reset it for you.
Dynosoar
I second the circuit breaker post.
If you find it tripped and it happens again... pull the fan motor out and clean all the sticks and leaves out of there. You may also find a bunch of trash packed in the air intake behind the wiper motor.
I park under a silk tree and find this area full of junk about once a year. It also can cause water on the carpet below the blower when it rains.
Ken
x3 on the circuit breaker
Problem solved
Dynosoar,
You hit the nail on the head !
Shoot who needs the FSM's I have IH8mud.
2mbb, thanks for the pic diagrams !
My breaker is labeled Heater...? I'd still be scratching my head if not for you guys.
Thanks again...!
