Wanted FJ60 shifter boot
Inverness, CA
Looking for shifter boot for H55 swap. If you have factor trans tunnel cover with cut out Ill take that too. LMK what ya got!
how about the H55 T-Case KNOB
and
the 4WD indicator switch H55
and the back up switch H55 ?
i have all NOS / NEW
thanks
also , the back up switch extension cord pigtail from switch to frame rail too ....
gots that too
I have a extra manual plate I’ll sell. And will do a nice discount on my plug-in harness with the purchase.
I also have clutch tube plumbing, crossmembers kits, etc
I need a manual boot/plate... and whats a crossmember kit? didn't see that on your site.
I designed a transmission crossmember for our in-house swaps. Only for use with the pre-85 (2F-style) belhhousings.
I have a few manual plates but only sell them if you are buying other parts from me
Looks like your starting with a US FJ62. What your wanting is an inspection cover from a 4/85-7/87 FJ60 in the US. That will bolt right in to your FJ62. Fill the hole for the automatic transmission shifter and the tunnel is done. Boots from that range will work as well. If your running a fat transfer case shifter your current one off the FJ62 will work.
Looks like your installing a diesel engine. How's that going to work in California or are you registering it in another state?
