I'm going to follow the route Pablocruise mapped out & mate an FJ60 relay rod (pitman arm end) to an FJ40 rod (tie rod end) as I have the parts, it seems most direct for what I have, and this truck is not going to be wheeled very hard.
To join them I was thinking of turning a piece of mild steel on the lathe that would match the ID of each piece. Imagine a dowel pin that would slip inside both ends where they would join. So one end of what comes off the lathe would be smaller to fit the ID of the FJ40 end and the other a little larger to fit the ID of the FJ60 end. Then weld together. Was thinking also of drilling a hole through each end, with each hole going through the connecting piece also, and put a pin through each hole to make sure there will be no separation.
So, does this sound like it would work and hold up or is there a better way with what I have to work with? I'm not sure what kind of forces are in play with this part of the steering system but anything doing with steering certainly has my attention and respect.
Or . . . what's better? I want to be driving a safe truck of course, but while being as economical about it as possible too. But if this ain't good, I'll spend the money to be safe if there's a better way.
