Wanted FJ60 Manual (4 Viewers)
Looking for center caps for a fj62
I just bought a sweet set of stock rims for my 1990 fj62 and need to get the front and rear center caps/rings. If anybody has a set that they don't mind getting rid of, let me know. I spent most of my budget on the rims and tires but would love a good set to top off the new wheels. I am also in need of the rear tire crank that raises and lowers the spare tire. If anybody is looking for some different rims for their 60/62 let me know, I would love to sell the american racing rims and tires that are on my ride now. Email me for pics.
Blessings,
FZJ80 Door parts and window switch as well as FJ40 Shackles wanted
I'm looking for the following...
1) Pass. side front door panel with the power window switch in it.
2) Door latches for a 1996 80, I'm sure any year 80 fits...
3) Shackles for an FJ40, not looking for stock...
i had the same problem with my warn 8274. rather than buy a new motor just looked in the yellow pages for electric motor repair and had it rebuild for $75, works great.
Wanted: Transfer Case Shift Boot
I am looking for the transfer case shift boot that bolts to the tranny hump on a 1973 FJ40. From my understanding it is specific for the 1973 model year.
WTB: OME Steering Stabilizer Bolt
Looking for the bolt that goes into the frame side of the OME Steering stabilizer. It's the long bolt that goes in through the stabilizer end and gets bolted down into the triangluar piece attached to the rig.
The other end of the OME stabilizer also has the same bolt but it goes into steering component....
Please PM me or email me at oazeri at gmail dot com.
TIA.
-onur
Akron, OH
I didn't see any 60 or 62 center caps on that site.
I like the rear caps, I would not use the fronts however
john q said:
This web site had them for $28.00 a piece, but they look good, you could probably bring them down a little. Good luckwww.ehubcap.com
WTB center diff lock actuator 96 TLC
I need the center differential lock actuator for a 96 TLC, this is the one from the transfer case.
Thanks
Just a FYI, the master switch can be had from any 4 door Toyota from 89 to 96 depending on the model. I got one out of a 94 4 runner awhile back and the Camry's work too.
WTB: 22R header
For 1985 Solid axle truck, good used header needed. PM me...
I am located in CO so I suppose the closer the better but either way PM me...
Thanks,
trade 40 & 60 parts for FastTrac soft top
Need:
a new style STC FastTrac soft top in black
Have available:
-1979 fj40 stuff
Holley carb with 2F adapter plate and K&N filter
(2) extra hard tops
(2) extra sets amby doors
extra set regular doors
(2) extra sets of jump seats
engine, front end, driveline, interior, etc from rusty but great running parts truck
(2) "visor shelves"... fit up high above windshield
-1985 fj60stuff
2.28:1 split transfer, h42 tranny
drive shafts (not double cardan)
fine spline axles/birfs
a/c compressor, lines, etc
water pump, alt
white hood
misc glass, window/door and grey interior/dash pieces
closable vents
full lock set
smog idler pulley
oil pan
Anyone want to deal plus or minus cash? I'd also be interested in a set of 33x12.5 AT's and/or an H41 in some kind of mix.
Victor--
Forgot to ask you during PM exchange...
Are you interested in the Husky cargo area mat? The black one with the sides?
If you do, I'm willing to send it off to you...it's a bit worn in, but it still works like charm
Let me know and I'd be happy to send ya pictures.
I'm going to herculine the thing!
later
-o-
