Wanted FJ60 Manual (2 Viewers)
You will also need a split transfercase and driveshaft modifications.
D-
If you are looking for a used one be sure to get at least one master key that is already programmed to it or it will not work. If this is for an engine swap a Tundra ECU would be a better choice as it does not have an engine immolbizer like the 100 does.
D-
Thanks for the reply Dan. I had no idea about the immobilizer issue. This is for a swap. Motor came out of a Sequoia. Going into my 93 4Runner. :D
Can you edit the title to say "WTB: 2001 Sequoia/Tundra V8 Auto ECU"
Thanks!!
Go back to your original post and edit it.
Since this is an engine swap you should use a Tundra ECU as those are the only V8 applications that do not use the engine immobilizer.
PM'd you.
PM'd You, landcruiserdude. Apologies 2badfjs!
i have a top that's banged up on the driver side, but the front and passenger sides are good. freebie!!! but you gotta come pick it up. i could chop off the pieces you need if anybody is heading that way.
hey shawn. is this what you need? if so, it's a freebie!
Hey Dan,
How many of the pre 85 transfers have you seen that have the oiler cup recess?
Dave
weber 38 dgms manual choke
Looking for this carb. In particular the Man-A-Fre Weber 38 Custom DGMS kit if available.
Please PM me if you have one.
Thanks in advance,
Cahil
COLOCRUISER said:
I am looking for a h55f tranny to put in my 84 fj60. email me if you have one or know where to get one.
I have been there. get a new one from CDan, or your favorite Cruiser mechanic. Get the split case while you are there.
Seriously. Buy new for your FJ, this is a good mod.
M
no problem david! if shawn does'nt need this one, it's yours. i might have another one, but i have not had time to dig thru my stash.
PS: went to the DMV on thursday and got the 63 put in my name. already have the new stickers on it. thanks again bud!!!!!
hijack over.
Btt
That looks to be right. Just please double check the size of the opening where the cap goes. I need it to be 1.5 inches. I now have 3 of the wrong ones. I guess people do not know haw to use a ruler or set of calipers. If you have another, I do need 2.
Thanks,
Shawn
looks to me like the opening on this one is 1 3/8". the OD of the neck is 2" at the top.
what different sizes are there?!
Rock Hugger:
I have some with a larger opening if that will work for you. Same shape at the picture above, but 1.7 at the cap opening, and no flap on the inside...
Shawn
The problem I am having is finding a locking gas cap th fit the larger (older) opening. no one seems to make one. I am having a problem in my neighborhood, where gas caps and gas seem to be growing legs and leaving my Cruisers. I guess if I can not find a OE one, I will have to cut and weld a newer opening to the older neck. Or something like that..
