Wanted FJ60 Manual (41 Viewers)
Rear Hard Top chanel/bracket thing
Looking for the piece that fits just above the rear lift gate on pre 75 hard tops. The part that the hinges atach to. It joins the two side pannel together. Need one that is not rusted out, and has side tabs still intact.
TPI Smokey Mt. 60 lift kit or OME
I'm looking for a used lift kit
pm me or reply :beer:
FJ-40 front axle with disc brakes
I need a disc braked front axle for my FJ-40. I also need a SM420 speed transmission. Im located in Gig Harbor, WA
3 Speed Transfer Case Front Drive Cone
My transfer case has a leak, and I believe it is because it has an ear missing (and therefore one less bolt) from the front drive housing cone. I'd like to replace it, I am not a welder yet, and I was hoping someone with a cracked case lying around would have a front drive cone from a 3 speed to spare. :)
SM465 needed in Cincinnati/Indy area
Looking for an SM465 in the Cincinnati/Indy area. Need a bare trans case at minimum to set up a V8 conversion. If you have an SM465 with an aluminum top cover and the shifter mounted way to the back of the cover let me know...that's the baby I hope to have for the final install!!!
Let me know what you have...
TIA,
Nick Jennings
4 speed transmission near Minneapolis
I'm looking for a 4 speed (H41) transmission for a swap. I might need drive shafts as well. If you got one and your near Minneapolis let me know.
I have a used one from a 68 Fj 40. It worked when I pulled it about 2 years ago. I will have to dig it out.
Whats a going rate for one of those.
Shipping from Columbus OH.
still need one? I can pull one off of my 65.
Still looking? If so I can help Ya out.
Sure do!
PM'd ya.
Dave
Need: Vac advancer for ~79 and up
The diaphragm is shot on mine and wont advance under acceleration. Looking for one that works.
Thanks!
Got a 4 speed/tcase setup out of a fj60 in central WI. Not sure what type it is. Email me for more info
FJ40 Radio Opening
FJX
