Wanted FJ60 Manual (12 Viewers)
need fj62 parts
thats some good info,,,if those parts are the same as whats on a 4-runner,,it will be alot easier to find,,,,thanks
con-ferr front bumper toolbox
Looking for one of thise nifty front toolboxes made by con-ferr. Anyone got one they want to let go of. Have a few cruiser parts to trade or just name your price.
Rob
BVSV valves needed
In need of both BVSV valves found on the thermostat housing of an FJ60.
Mine are pink and faded purplish gray.
Thanks
Ignition Coil
I think I need to replace mine. I've had an ongoing problem with my FJ60 "missing" and it could be the coil dying slowly. These are super $$$$ new; I'm looking for decent quality at $ cost. Isn't everyone :rolleyes:
The igniter would probably go with it....
Ignition Coil
Just a thought, but I spoke with Jim C of TLC performance on this. Basically he stated a coil is a coil is a coil. If you want strictly OEM for stock purposes thats fine. I got a new Summit coil for 15 bucks and it works fine. The ignitor would need to come from a donor toy though.
Ignition Coil
I have been able to get the accel Super Coils cheep from ebay. Be sure to get one with the balast resisitor if you are going ot keep using your points system. HTey are cheep and make a great spark. they are the big ugly yellow tihngs with the brown cap.
E
FJ40 battery tray support bracket and fan shroud
Need an FJ40 battery tray bracket, mounts to the frame, and the battery tray mounts to it. For a 1976 FJ40 so I think 72-78 would work.
Also need a fan shroud for 8/76 and newer fj40 with a fan clutch.
PM'ed you.
Early Mini driveline bolt flange needed
Like the Title says, I need to get a Driveline bolt flange for a mini pickup 79 through 94 would work. I have the rest of the Dline....
Here's a pic of what I'm lookin' for:
Found one
Found one fellas, thanx!
Brake proportioning valve
I'm looking for a rear brake proportioning valve for a 1978 40? Mine is leaking a good amount.
2F VSV valves needed
Please send me your unneeded BVSV valves that you are now using as water plugs!
I need the emissions vacuum control valves found on the thermostat housing of a 2F engine.
Thanks
y'all are correct.
perhaps i was blinded in a fit of rage...
FJ/FZJ80 Rear Coils Wanted
Looking for 2 rear "short side" coils from FJ/FZJ80. These are going on a 93 4Runner. I'll consider two standard sets (1 long/1 short) if the price is right.
Zip is 15139 for shipping.
Post here, PM or EM me. Thanks for looking.
i've got both items if you haven't found them already. $20 plus shipping
