Wanted FJ60 Manual (51 Viewers)
Re:NEEDED BAD!!FJ40 Gas pedal assembly
I guess its for the 72, in which case I think pedal I have will work. Your truck has a cable linkage right? You can e-mail me dirrect at cruise1977@aol.com.
- Josh
Need a MINT pre-79 frame in Mid-atlantic area
If your interested I have a '77 FJ40 with a good frame that I'm selling. Its a parts or project truck. Tubs all rusty, 2F is mostly stripped, and the trans is gone. It has the hardtop and doors which are in average condition. It has a good windshield frame. And of course the disc brake front end. $1000.00. You can contact me dirrectly at cruise1977@aol.com.
-Josh
Hedlight Bezel Needed
I have one, I think it might be a little rusty, but not bad, just needs cleaning up. If your still looking for one contact me dirrectly at cruise1977@aol.com.
-Josh
Wanted- Rebuilt Low Mileage F Motor
I have a 74 F that you can have if you want to pick it up. I think it needs some rings though, the gut I got it from said it smoked. I just thought if you were going to rebuild an F you might want the full filtered oil. cruise1977@aol.com
-Josh
i want some TJ fender flares
i am looking for some tj flares for the rear. i will pay 50 for the pair. Original equipment prefered.
Early F upper t-stat housing
I've got a couple, but there's some pitting going on too. Let me know if your other ones fall through.
Idle Solenoid
Like the discription says, I need the Idle Solenoid to get my truck running.
Located in TX,
Thanks
Upper front passenger door hinge FJ55
I need a front passenger door upper hinge for an FJ55. Our's is a '2/76 production if it makes a difference. Our's has excessive play and is causing the door to sag too much (more than I can counteract with adjustment in the hinge mounting).
Rear bumper for 64 FJ45 Wagon
I have a '64 FJ45 Wagon (four door, not troopie) in need of a rear bumper. I'm looking for an original, as straight as I can find. Let me know if you have one you're willing to part with.
Glenn Reid
Woodside, CA
Idle Solenoid
Idle Solenoid Part Numbers:
2 Wires (8/80-93)
GP Sorensen 7791933
Niehoff Ignition FS637
Borg Warner ECS508
1 Wire (1/75-7/80)
GP Sorensen 7791930
michelins for an 80
I need two very good condition Michelins for my wife's 80. OEM size and model please.
Thanks!!
Front Axle Hub
... Looking for the front axle hub to fit a 68 FJ40. I believe later years will also fit... til something like 74 or 75. Perhaps some of you know better than I ?
Anyways I'll include a picture so you know what I'm talking about. My email is enosence@hotmail.com
FJ60 little rubber thingey...
Mine busted - need a workable one if any of you have one. Toyota no longer carries the part.
Please check and let me know?
Thanks
Mike S
mike@uxcomm.com
Re:75 or pre-75 hardtop for an fj40
Residual,
I'm in Orem. Let me know and I can take some digitals and email them to you direct before you take a trip down to look. Sorry It took me so long to get back to you. Been in Moab for a few days wheeling the 80. Too fun.
trent
Re:Front Axle Hub
Socrates,
I might have one for you. the axle is a 69 but I haven't had time to pull it apart to see if it is any good. I'm in Utah.
Trent
Flat FJ40 springs
Looking for a set of fj40 flat spring so I can use them for a spring over. I have a really good set of stock ones I can trade. I have a good arch on the still. I wouldn't want to pay for shipping but If we are trading, I would.
Thanks.
