- Thread starter
- #541
Okay, so in moving towards street legal. I'm going to need seatbelts. I can't find anywhere it says whether they have to be should belts, or if lap belt will work. I'm guessing, since this is new construction, is has to be a shoulder belt - which I have no way to rig without putting the top on - or installing at least a main hoop for the roll cage. So, I'm trying to figure out how I can get a hoop made that will fit. I don't have any of the equipment. The OEM stuff is available, but that stuff is so lightweight, I'm assuming it's useless. Is it? Does someone make a hope that will fit and is worth buying?
The classic thing to do on a 45 is to put the roll bar/hoop behind the cab on the flatbed. It's cleaner and leaves the cab unencumbered, but it provides a less protection then a full cage inside the cab. Plus, with the bar behind the cab, the only place I could mount the shoulder belt is to the sides of the top (which are fiberglass, not steel). and I'm assuming I'm running this without a top most of the time. Is there any other way to rig a shoulder belt?
