Wanted FJ60 front spring hangers (1 Viewer)
  1. 60 Series
California United States
Hello
I’m looking for a set of front spring hangers for an FJ60. Specifically the very front that hold the shackles. New, good used, or aftermarket leads appreciated. Maybe someone here fabricates them?
Thanks!
The issue with the Ruffstuff hangers is they don't use the Cruiser bushing - and the ID is different so your shackle pin will be a loose fit.
One of those things that is fine for a trail rig, or solved with some machined sleeves if you really want it to be right.
In the past when I had more time I used to hand-make these to use the Cruiser bushing, I could make more but they would be more of a production version. Probably $150-200 pair
Thanks for the info. I did run across a thread that mentioned your pieces. I’d be interested in a pair, possibly two if you get a run going. Maybe others are interested?
Pierre
