- Joined
- May 31, 2015
- Messages
- 53
1984 fj60
EGR 75
Oil cooler 75
Driver's side rear light cover small chip on side 10
Grill 50
Light doors with blinkers 20 a side
Metal lower part of dash 40
Fuel pump 30
Manifold cooling fan 20
Coil/igniter 50
Wiper fluid tank 10
Thermostat upper/lower housing 40
Intake manifold 40
Round dash vents 5 ea
Door arm rest 5 ea
Door plastic side pockets 10 ea
Rear view mirror 15
Steering wheel 30
Glove box liner 10
Little black compartment in dash 5
Outside chrome handles 5 ea
Window regulators 15 ea
Oil pump 15
Rear heater 25
Alternator 20
Ash tray 10
Inside door handles and latches 10 ea
Grab handles 5 ea
Water pump 20
Pass. Door mirror 20
Drivers side door mirror glass and parts still good. 10
Shifter boots 10ea
Fan clutch 10
2 rear seat belts 15 ea
Plastic by feet and door on front 10 a side
Plastic trim between rocker and door 5 ea
Door ash trays 5ea
Cig lighter (lights up) 20
Wiper connection. Rod 10
Over flow violent tank 5
Wiper access panel covers 5
Radiator 20
Clutch mast cylinder 15
Fuse panel cover 5
Hood release cable 10
Tranny dog house cover plate
Heat/air instrument control
Brake pedal 10 clutch pedal 10
Fuse block 20
Rear hatch shocks 15ea
Instrument cluster 50
Rear wiper rear heat buttons 10 ea
Door hinges 10 a door
Fly wheel 75
Door windows 10ea
Rear side windows 10ea
Hood arm 5
Hood hinges 10 a side
Hood spring 10 a side
Bumper hook 5
Drivers seat belt 20
Pass seat belt 20
Interior dome light 10
Center console small crack bottom rear 15
Rear hub center 10
Front hub covers 10
Dash blank black switch cover 2.50
1978 Fj40 parts
Brake booster 100
Brake master cylinder 20
Kick vents 10 a side
Ash tray 5
Fuel fill line and breather cover plate 15
Heater 40
Clutch master cylinder 15
Radiator mount holder 15
Cowl vent cover 10
E brake lever and bracket 15
EGR 75
Oil cooler 75
Grill 50
Fuel pump 30
Coil/igniter 50
Wiper fluid tank 10
Intake manifold 40
Door arm rest 5 ea
Rear view mirror 15
Steering wheel 30
Glove box liner 10
Oil pump 15
Rear heater 25
Alternator 20
Ash tray 10
Grab handles 5 ea
Water pump 20
Shifter boots 10ea
Fan clutch 10
Door ash trays 5ea
Radiator 20
Fuse panel cover 5
Fuse block 20
Fly wheel 75
Door windows 10ea
Hood arm 5
Bumper hook 5
Pass seat belt 20
Rear hub center 10
Front hub covers 10
1978 Fj40 parts
Brake booster 100
Ash tray 5
Heater 40
Cowl vent cover 10
