FJ60 Cooling Fan after engine off
So Cal
My cooling fan does not turn on after the engine is off. Consequently, when I jump back in and turn it on the temp gauge is marking close to the red zone. Luckily it comes down but being so close to the red is not a good feeling especially when I may be driving in 100+ degree weather. Any diagnosis or repair suggestions? Thanks
Welcome to IH8MUD rookie!
You're describing a common problem that's been discussed a few times.
Try the forum's SEARCH function using the keywords CARB FAN.
You should get something back like this:
Search Results
Read up and then post up if you still have questions, or even better, post up your success story!
Good Luck,
cooling fan is not to cool the motor, just to cool the carb and line and i suppose the manifolds.
the temp will keep rising after shut off....its normal and nothing to worry about, it will drop almost instantly when started.
Yep, very common on both counts. Others may tell you that the rise in motor temp is a sign of a stuck thermostat, but it's just risidual heat build up because coolant is sitting, not moving past the gauge (I think - could be wrong though) - so long as your temp drops after startup, you're fine.
Get that carb cooling fan fixed as soon as possible. The heat and the vapor lock it causes makes a mess of the carb and can have other ill effects as well (I blew out a fusable link because I got mad and ran the starter too long as a result of no gas in the carb.)
Thanks guys! Carb fan working well and sounds like we all agree the radiator fan doesn't turn on after shut off and all is still well.
If your truck has an electric fan, it's aftermarket. Really no reason to have it running after you've shut down. Stock is a mechanical fan.
Your carb cooling fan is a totally different thing. It's mounted on the driver's side fender well.
I have a 62 with an inoperative electric fan. Mine blows on the intake. I have checked the temp sensing unit and cleaned it off. I am unable to locate a fuse. I want mine to work too.
Any 62 owners out there with successful repair stories?
search the threads, but I'm thinking that Landpimp said his 62's cooling fan hardly ever kicks on.
You could test it by running a hot wire from the fan to the bat and make sure it kicks on.
Also check your FSM and see if it has a testing proceedure in it.
my cooling fan almost never turns on, on either the 62 or 80, I has but its VERY seldom.
on the 40-60's it kicks on EVERYTIME I turn it off.
check dome light fuse on 60 and maybe 62, I think someone said its tied to that.
I have read many a thread concerning the carb cooling fan.
In my 88fj62 it does kick on anytime the ambient temp (outside air) is over
about 85 and I have been driving a while. It won't kick on right when I shut the
truck down however. It sits there idle until the heat builds up under the hood then
kicks on for a few minutes until it cools down a little.
hits 85 seldom in WA..........so thats prolly why mine never kicks on ;) but I do recall it taking a while to kick on after shut down(when it does kick on) Now on the 2f's it kicks on RIGHT away.
Texas Heat
I am fairly certain it is not coming on. I have had it almost a year and never heard it come on. I live in Dallas and it has been over 90 for several days.
What is it hot out here?
The 85 degrees is just a guestimate to get in the ballpark on my part. It really doesn't
get much of a workout on mine since I drive the 40 so often in nice/warm weather.
Obviously the carb fan is going to run more in Mo. than in Wa. It should anyway!
Point well taken.....
Out of ignorance I must ask....Which years/models did the 40s have carb fans?
Its pretty typical for the wire going to the sensor (located under manifold towards firewall) to burn in two. Check it first.
