FJ55 40 gallon Long Range Fuel Tank
CouleeDamWA, BoiseID
Ok so I did the math once more and this is what I have for volume.
These are the measurements I have with photo's below measured with a yard stick.
20" x 33" x 10 = 28.571 U.S. gallons
10" x 33" x 6" = 8.5714 U.S. gallons
(4" x 33" x 10") / 2 = 2.85715 U.S. gallons
= 39.9955 U.S. gallons
So originally it was said to be a 34 gallon tank. But after doing the math it is a 40 gallon tank.
I used this calculator Volume calculator - Math Central
I believe this is an MAF extended range fuel tank. It's professionally built, high quality, aluminum fuel tank with fuel sending unit, proper located vent ports, fuel out/return ports, and filler port, proper tank baffling. The tank is reasonably lite. The tank installed hangs maybe an inch below the frame rails. If you lift the body 2 or 3 inches then you could also raise the fuel tank another 2 or 3 inches and tuck it inside the frame with a rock guard.
My FJ55 is diesel so the tank has been filled with nothing but diesel.
It's an awesome tank I'm just going into another direction. I'm moving to Spokane, WA but the tank is still in my shop in Grand Coulee, WA
Basic Measurements 30" x 33" x 10"
500 obo
OR Partial and/or Full trades.
Hey bro....
No plans to come back that way for some time. I might be taking a trip down to Boise to visit my parents before winter sets in. But I would more then likely take the MINI down because of fuel prices.
Im sure we could figure something out .... maybe mud or freight?
