I am in the process of converting my 68 FJ40 into a 4 speed. I took it all apart and find a lot of oil in the clutch area. I had noticed the clutch was slipping a lot more.
From what I can tell the leak is either from the rear main seal or through the flywheel bolts. I will post the pictures so you can analyze and confirm.
I see some oil lines coming from one of the flywheel bolts. Is this a common area that leaks? I put on a new clutch and all about 3 years ago.
Do I need to use some kind of thread locker and sealant in the flywheel bolt holes?
Also, there is a flywheel alignment stud piece at the top between the bolts. This seems to be loose. I would think I should use thread locker and sealant on that too? Can anyone confirm? I find it very poor design for these bolts to be open into the main oil chamber of the engine. There is no reason for this and it is a big risk. Has anyone ever built a cover for this?
Also when I look at the flywheel plate it looks like loose stud piece has slightly pushed up metal of the hole it sits in and may be causing the main seal to leak.
Does anyone think that is the real issue here? Is there a way to fix this? Or do I need a whole new crankshaft?
The pressure plate looks ok. But the clutch is toast.
Any pointers would be appreciated. I don’t want to put it all back together to have it leak again.
