FJ40 glove box lock : know where to find this aftermarket latch lock?
east bay, ca
hi MUD nation
i have an '82 FJ40 which had an aftermarket latch lock put on the glovebox. I don't have the key so looking to replace it.
anyone know where i might be able to find a similar latch lock?
thanks
Home Depot, Lowe’s, local hardware stores... :D
My 79 has the same lock minus the key to be able to lock it.
Fix would be
A buy a replacement lock.
B replace the glovebox door with one from my stash.
C replace glovebox door with the 8/80+ style glovebox door.
Think I'll go with option C. Current style adjusted so it doesn't rattle is a pain to open from the driver's seat. Twist style makes this easier. Do not keep anything worth stealing inside the glovebox. With a lock thief might think there is something worth stealing and cause damage breaking in.
@ToyotaMatt Its possible to have this glove box lock keyed to match your ignition/door/fuel door?
Over the last year or so…
I have successfully created the needed step by steps and sourced the Japan Spec. Lock and Key Service Parts Needed and now routinely Re-KEY / Re-Code any OEM Toyota Locking Gas / Fuel / Diesel Cap that uses a 2 sided / Double sided factory key profile ……1973-1997 All Vehicle Platforms globally including Land Cruisers ….
However ….
I have went at the Locking Type Round Twisting style OEM Glove Box door lock above ⬆️ in my Classified ad here un-successfully ….😕
Do to the way it’s Press-Seamed together at the Factory in Japan 🇯🇵 … I will say for now this is Not Possible , and I can say for a solid degree of certainty, that I do Not think there is a method or technique to do this correctly ….
I had / have several pre-owned same exact glove box locks , and I tried 2 different approaches….
no-go unfortunately….
The Good newz is each NOS OEM locking glove box lock I have , includes the Factory Key Code either stamped on each OEM Key Shaft , or on a included OEM Toyota little Chrome Tag shown in the photos above ⬆️
In some cases both the keys are stamped and the keys 🔑 include a little chrome key code tag , but NOT all the time ….fyi
However ….
Appreciate the response and bummer. That would have been pretty sweet if so
