SOLD Fj40 full 3.73 front axle
Corvallis, OR
My front knuckles need service and want to swap 76 FJ40 to 3.73 gears. Thought I would see someone has a good condition front axle that would solve both of my problems at once (knuckles in good condition and 3.73 gears installed).
I'm in Corvallis, OR
it would be easier to install a later diff with 3:70 gears and go thru your knuckles at the same time. you will also need a matching diff for the rear.
I've got diffs, they are easy to ship.
I also could supply a complete axle that was gone thru but between the cost of the axle and shipping it's going to be pricey.
I was really hoping for a 79- 82 fj40 entire front assembly from disc brake to disc brake. Figuring that if the knuckles and 3rd member were in good shape, I could just put it in rather than rebuild the knuckles and 3rd member. This of course is only if cheaper than buying 3.73 3rd and rebuild of my current knuckles. I'm currently driving on my setup.. just needs service and the change in gear ratio.
If I stick with what I've got then I'll swap 3rd members as you suggest while rebuilding knuckles on the front. How much would two (hopefully front) used 3.73 3rd members cost shipped to 97333?
