SOLD FJ40 Fuel Separator
TN
Looking for a good 40 series fuel separator. Not sure if there’s any different versions for different years but it’s for a 74.
Thanks
Thanks
define the seperatior ?
photos please
i have tons of charcoal NOS canisters and check valves nos too
i dont understand this term seperatior
thanks
Sorry. Meant to say fuel vapor/evaporator separator. The plastic piece the three vent lines come off of the fuel tank to before the check valve/charcoal canister.
This picture from CCOT shows it.
Do u have your Related and Needed Little White Check Valve ?
if not , i keep ONLY the HEAVY DUTY COLD CLIMATE Spec. version in stock and sourced ONLY direct from JAPAN ........
I am looking for an early 73 only 2-hole version, or a 3-hole version damaged on the one-hole side that I can cut off. I don't want to cut into a good 3 hole unit.
Did see your ad, looked. Only have 3hole version.. you could cut the one hole side off if won't fit? @Engineer8000
That is my plan B. I have a good 3 hole separator but hate to hack into it.
Chop it! Never seen a 2 hole version...
