Hi everyone,
I’m at a loss and need some advice. I have a 1975 FJ40 with a Chevy 350 and an Edelbrock carburetor. The vehicle has been completely redone, and I’ve had dual tanks installed:
• New tank under the passenger seat (replacing the original).
• 20-gallon tank underneath the rear.
It’s running an electric Edelbrock fuel pump, a valve to switch between the two tanks, and (reportedly) one-way valves for each tank.
Here’s the problem:
After driving about 10 miles, the truck dies. I figured out that I need to prime the fuel line when this happens, but I can’t figure out why it’s losing fuel delivery.
Some additional info:
• Tank venting: The new 20-gallon tank has a gas cap with a pinhole for venting. The original tank (also brand new) does not have a pinhole.
• Charcoal canister: Has been removed/mitigated.
• I’m not sure if one tank might be pumping fuel into the other or if it’s vapor locking.
• The mechanic who installed it hasn’t been much help. He suggested converting to EFI, but even admitted that wouldn’t solve the issue if fuel isn’t reaching the line.
Questions I need help with:
1. What is the usual configuration for a dual-tank setup with an electric pump?
2. How can I tell if fuel is getting pulled from one tank into the other instead of going to the carburetor?
3. Is the venting situation adequate? Should the original tank have a vented cap as well?
4. Could vapor lock still be an issue with an electric pump?
5. Any tips for troubleshooting or fixing this?
I’m completely baffled and would appreciate any advice or guidance.
Thanks in advance!
Here’s the problem:
Thanks in advance!
