Are you running gen3 or gen 4 LS? You really need to bypass the fj60 amplifier completely for it to properly work. Its old technology and you really want to have your GM Computer controlling the entire AC System instead of kind of hodgepodging it together with the toyota stuff. Using the toyota amp is kind of unsafe because it does not have a high pressure switch in the system, so if you overpressure it will just dump the freon out of the relief valve on the compressor, and your GM computer wont be getting any information of the state of the AC for the rest of the operation like fans and WOT fan cut off and AC Idle speed increase.
If you are running a
gen3 motor, youll need the proper PCM that has the IAC drivers to run the Air conditioning, then the rest is just wiring and having a high pressure transducer on your high pressure line. It seems like a lot but its really pretty easy to get it to work.
Ive got it all listed out at the link below for a Gen3 motor. If you do your wiring exactly like that, and follow the way i did it, then have a tuner turn the AC request to ANALOG, you can watch the function of the AC button being pressed, the computer telling the motor to idle up, the pressure transducer reading the ac pressure, and the computer telling the fans to turn on all in that order on the computer in HP Tuners. Its pretty neat
forum.ih8mud.com
