Fj 62 starter replacement
oahu
Hey guys! Need to change my starter on my fj 62. Any advice on best way to remove and what tools would be best? Just looking for the best way and if you guys think it’s a rough job. I know my starter is kinda crammed. Please and thank you guys!
First thing to note. Unplug your battery. It should be two bolts and it comes right out. New one goes back in. Wires go back in the same place.
Essentially this ^^
Unplug your battery, 12 mm wrench or socket to disconnect the battery wire at the starter, unplug the other wire, then a 17mm to remove one bolt and one nut. It's not difficult.
If your old starter is OEM keep it and rebuild it.
Essentially this ^^
Ok and what is the easiest angle to access the back bolt and should I use swivel sockets
Lay on your back, crawl under the Cruiser and look up. No need for swivel sockets, just use a normal ratchet or long wrench. Upper bolt is a little more difficult because you have less room but it's not that bad.
Ok yeah that’s the bolt that I was most worried about getting to haha, 17mm. Ok thank you guys for help
Since I’m on here, I checked my CEL with a paper clip and it gave me number 23. Anyone know what that pertains too?
Had to do this today. Very easy from under the truck. Safety glasses are a good idea. Had toPB blast the bolt on bottom and the nut on top(accessed from the top). Easy job. Toyota still carries the starter and will give a rebate for the core if you don’t want to rebuild it. Electric socket wrench from harbor freight is your friend for the top bolt and many other hard to reach parts under the hood on these trucks.
What does that mean? There nothing for that code
It means you read the code wrong.
As I recall the starter replacement on FJ62 is easier than on 80 series, although neither presents much difficulty.
Correct. The 80 series top nut is a little more difficult but only because you have to work past a thick wire bundle which blocks a clear view of the nut.
