Hello,
I recently converted my 68' FJ 55 to a four speed transmission and transfer case, all went well except for the drive shaft issue. I have access to the original 4spd driveshaft, the only problem is the flanges on the 68's axles are the small bolt patter and the transfer case is now the large pattern. One thought is to use my 3spd transfer case and shorten/lengthen the original (3spd set up) drive shafts. The other option (not sure if this is possible) use the flanges from the 3spd transfer case on the 4spd transfer case and shorten/lengthen drive shafts. Any thought. would be greatly appreciated.
