Fixing KDSS first, or do 4 wheel alignment first?
Hong Kong
Hi all, just having a new spring installed with 40mm lifted. So the right hand side of the vehicle is lower than the left hand side now because of the KDSS lean.
My concern is, should I do the wheel alignment first, or fixing the KDSS leveling first? Is there any different for doing any one first? Thank you!
Fix the KDSS and make sure your vehicle is level. If the RH side is significantly lower, especially in the rear, you may need to swap the left and right rear springs, especially if the taller one was mistakenly put on the drivers side.
Anyway once you fix the lean you’ll find the alignment will change, so no point in aligning first
Yes - if it was installed according to the instructions from an australian company, they refer to Drivers side and passenger side, which are opposite in AUS since its RHD and we sit on the LEFT.
The KDSS system should have no-lean at all, almost all of these instances are the result of improper installation of the springs that i have seen. All the springs are typically marked for side as well.
Thank you for your help, will find a leveled ground and try to fix the KDSS.
