OK, so I made a colossal mistake and it’s pretty darn embarrassing to have to fess up about it, but I need some advise.
Basically, I used some short screws to bolt a box to my driver’s side passenger floor and the fuel tank was closer to the floor board than I realized. Apparently, it’s right up against the floor board. These screws were only about 1" long. I should have known better and I'm kicking myself up and down right now.
The hole I made is extremely small, but it’s enough that it needs to be repaired and that means dropping the tank I’m sure.
So, my questions are does anyone have any advise regarding dropping the tank? I can see the exploded diagram in the manual and my thoughts are draining the tank using a drop in hose into the fuel filler (I don’t want to undo the plug if I can avoid it) . Then undoing the fuel filler rubber hose, then unbolting the sending/fuel pump unit from the tank, pulling it out of the tank and leaving it hanging up by the body as the tank drops down.
Looks like there’s some gaskets I’ll have to replace as well. Maybe put a few fuel filter in, since I’m already there.
Does this sound like a plan? I’m afraid I’m overlooking something. My biggest concern is dropping the tank and how heavy it might be.
Finally, once the tank it out, what’s the best way to fix the tank. It should be just a very small hole. I’m wondering if I should use something like JB weld, or RTV or some combination or is there something better? Once I get the tank out, I want to do it right.
Thanks, I'd appreciate any advise.
