I got this truck a few weeks ago and absolutely love it. I replaced an 05 Honda Pilot, which was a good vehicle, but not in the same class. However the Pilot had one thing going for it, simplicity. The LX is a much more complex machine and therefore requires more maintenance in the end. One of the first things I noted was a sticky pedal, and this only applies to drive by wire rigs, I think.
Toyota says not to lube this mechanism but doesn't explain why. I thought it was to prevent contamination in the sensor but I think the real reason is how the peddle itself is constructed. If you look at the peddle you will see a large spring wound around a black barrel that the arm of the peddle runs through. It is this barrel that is the source of the stickiness. It's not simply a plastic bearing, rather it has an internal mechanism that acts as a friction brake to impede rapid changes in the peddle. I don't think it's for the sake of the throttle mechanism rather it's for the driving experience.
I removed the mechanism thinking it just needed a good cleaning and fresh grease in the specific areas. What I found was this this brakingechanism is worn and doesn't brake smoothly anymore.
In the end I simply removed one bolt that affixes the barrel to the peddle assembly which allows the barrel to rotate as the peddle rotates. The result is no more sticking peddle, however much of the resistance is now gone so the peddle is very light now. So I could see if you were in a situation where you are being jostled about your foot would probably be bouncing around too. In that situation you'd probably be giving throttle inputs that you didn't intend to give.
Mind you, it's not like there is NO resistance, just dramatically less than with the barrel affixed to the mechanism.
For those looking to do this, I'd probably recommend just getting a new peddle assembly which is what I will do now. Toyota sells just the peddle without the sensor for about $50 I think. If you are going to do this job just replace it because it's a royal PITA to get that damn thing off and back on.
