First coat on bare metal
I am continuously in the process of cleaning and painting lots of small parts for my cruiser: hinges, latches, bumpers .... I generally sandblast everything to bare metal. I would love to find a local plater who would put electro-zinc on the parts as a base coat, but I have had no luck. So, I am trying to figure out what the first step should be -- self etch? epoxy primer? Something from Eastwood? My main goal is rust prevention. I hate rust so much I would dip my stuff in pure zinc if it would take paint afterwards (but it will not).
Since I am always working in small batches, it would be good if I could find something great that's available in a rattle can.
I would say that my primed stuff often sits around for months before it gets shot with the final coat. So, the ability to re-sand something before the final coat is important.
Also, as a novice, I tend to put too much paint on things, which leads to bad results I have found.
So, what should I be starting with?
Thanks guys. I have used epoxy paint with the little Preval guns. It has to be thinned a bit to work. I guess that's the best choice to stick with.
I do use Zero Rust but am reluctant to use it on body parts that will receive my finsh coat (Concept 1-Part Urethane).
For small stuff like that I normally clean to bare and hit with some rattlecan Zinc Rich Primer that they carry at local car shops. Works as a great first primer and should do a good job or preventing rust.
Plus it comes out quite different than conventional rattlecan stuff, more of a powdery substance, but sets up like normal paint. You can cover a whole hinge with just a couple sprays. That should help with the overpainting ;)
Rust-O-Leum Rusty Metal Primer, don't waste time with anything less. I can tell you from experience it will still be on the part twenty years from now.
How is the zinc rich primer different from galvanizing in a can (which is about 95% pure zinc?(
