FINALLY got the stereo in.... (1 Viewer)
Richmond, VA
FINALLY got the stereo in.... (pics - big!)
Well, it has been a saga that I won't soon forget. I started off thinking I wanted to do something that would not be seen (use factory grilles and such), but that became more and more difficult.
I started by buying an Alpine 9827 HU. Great unit, even if it illuminates blue to the LCs green. I bought the Metra Universal Toyota wire harness from BestBuy. It was labeled well, as was the Alpine. I wired it up as noted, but when I hooked up the power, it would cut on and then off immediately. CD worked though. Found out that the Metra harness was wired wrong for the LC with auto antenna and manual buttons. It had the antenna on wire going to pin 9 with a loop back wire to pin 8. The antenna on wire MUST go to pin 8 and you must cut the loop-back wire, terminating it and the wire to pin 9. Auto antenna and buttons work! :bounce:
Next, had to figure out what to do about the space in the back. The stcok "sub woofer" was a joke to say the least. So I took it out and thought I might put a sub woofer (a real one!) there. But, alas, the depth isn't very good and if you want to do it, you really need to know something about fiberglassing because the angles in there would be tough with wood. I finally decided to do a 10" subwoofer in small box and put it in the back. It could easily be removed so it really wasn't in the way.
Now, what to do with ALL that empty space where the sub was? :idea: I decided it was a great place for an amp. I found a great deal on an Eclipse PA5532 5 channel amp, with 50x4 RMS at 4 ohm, and 1 @ 280 at 2 ohms. BUT, it is 12 inches wide and 19 inches long and weighs 15 pounds! Thank heavens for that cavernous space, even if it was odd shaped. Now I had to find a way to mount it. AH, the welder that I bought and haven't used enough yet! I had some scrap metal and built a bracket to fit to the two factory holes on the top that the sub was hooked to. I made another bracket for the bottom to keep it from swinging.
I then ran cables ALL over the place. 4 gauge power wire from the battery, down the left side and across the back to the amp. Speaker wire to the front and rear doors. (It sure was nice of Toyota to leave BIG channels in the floors under the carpet for running wires!)
Now come speaker decisions. I have all this time and money invested in a HU and amp. No way I am going the cheap (excuse me, inexpensive) route. So, after listening to many speakers, I have to say I fell in love with some MB Quarts. The PCE 216 6 1/2" separates (Premium series) spoke volumes to me. But do I really want separates? Where would I put the tweeter?? Fortunately, the MB Quarts have a fantastic design that lets you set the speaker up as either a coaxial or a separate. Great stuff! I thought this would give me options when I got to the install. But that looked like a huge job, so I decided to start in the back.
I bought MB Quart 4" coaxial speakers (Reference series) for the rear doors. When I opened the box, I will have to say that even at 4", these are hefty speakers. I am used to little cheezy looking things at that size. Not hear. And they came with a separate external crossover. I ran the wires through the rubber boots into the door. But I decided that I didn't want to worry about the factory grilles. As a start to my "fun", the new grilles weren't big enough to cover the openings from the factory grilles. :mad: So I cut out the center part of the grilles and lo and behold, the trim rings fit right in and the speakers look like they have risers. These speakers are AMAZING for 4" speakers. I ran them and the sub for a day without the front speakers, and though not great from the front seat, if sitting in the middle seats, more than I would expect from 4" speakers.
Ok, after monkeying with that, and cutting the factory grilles, I figured I was up for the challenge of the front speakers. To start with, 6 1/2" speakers don't look that big until you try to put them where the factory fronts go. OUCH. Well, I didn't want to have to cut, but..... You cannot, repeat cannot put them in the exact same location as the factory 5 1/4". Mainly because you will not be able to close the door because the speaker will stick out too far. I had to move mine to about 7 o'clock just a bit. I cut the panel and fortunately didn't have to cut any metal behind it. I did ground problem when putting the speaker in, so I made sure to use some electrical tape around the opening and over the connections to make sure no metal to metal contact happened.
Now what to do about the dang tweeters? I paid all this money for NICE separates, so let's see....... No room on the A-pillar, really. Don't want to mount them behind the vents (some have done it with success). I have already started cutting panels, so what do I have to lose? (My sanity, of course!!) So I decided to angle mount them just above the door latch and lock. Now we are in for some serious cutting. Once the knife puntures the vinyl, I know I am committed (why is it that even with music playing in the garage, the "pop" of the knife going into the taught vinvl sounds like an explosion....are my nerves giving way.........) I use the templates and cut the holes. To do this, though, I had to make sure to move the tweeter back just a bit from where I wanted it. There is a screw back there holding the panel to the upper piece. Must avoid screw ups......... I then get the Dremel out and tenderly cut the hole. Undersized and then make a little bigger, test fitting as I go. You can't put plastic back (don't ask how I know). I have it all together and decide to test fit the panel. Looking good, got the top part on, lining up the bottom.... CRAP. The tweeter is now protruding out of the panel. WHAT THE $!$!$. The nut holding the tweeter in is pushing against the metal of the door. Well, I'm committed now, so I get out the drill with a BIG bit and drill a hole for the nut to fit into, allowing the speaker to fit as intended.
Once I got it all buttoned up, I yelled to the wife and kids we needed to take a test drive and get some ice cream. Everyone gets in, I close the garage and when I get in, my 14 year old son says "This sounds great Dad!!!" :cool: My teenage son has just made me feel young again!! And we haven't even left the driveway.
Needless to say, there is lots of playing and tweaking left to do, but that is part of the fun.
Congrats on the install. I am about to start mine this weekend. How about some pics?
Pictures!!
Empty whole in the back.....
The amp...
Brackets I made for the amp...
Brackets on the amp...
Amp mounted....
Cover back on...
Sub box....
Rear door grilles cut...
Trim ring in...
Speaker in the door...
Front panel off...
Panel cut...
Better shot of how cut is offset...
Hole for tweeter (forgot to take on the driver side)...
Tweeter mounted (from back)...
Hole I had to cut for tweeter...
Tape around edges to prevent grounding...
And on speaker terminals...
Crossover for the right side (beefy things!)...
Front door finished....
If you look close, and turn your head left, you can see a little room left without hitting the dash...
A shot from the floor to show it is a big speaker...
May have over done it on the pics. Please forgive me.
Many thanks to all that have given input. Heffenoche for talking about dimensions and such before I pulled my panels; Brentbba for sending some pictures of his great install (still want to know how those center channel tweeters are wired.....); and many others who posted when I asked questions or have put info here before. Great group of folks here. Hope I can return the favors!
thanks for posting pics. You can never over do pictures.
Wow! Stress, that set up looks great. Glad things worked out well for you. I look forward to getting my system. How much did you end up spending for the complete set up? Also, which wires did you use to run the amps and speakers?
Steve
Very nicely done - great post and pics! Best stereo post yet - I guess you can now change your sig. Have you done this before (wiring stereos) or are you a newb?
Cheers, Hugh
Seems like you had a fun time with the install. This was my first actual mod to the LC and has been worth every second.
I like your amp install, mine wasn't as well done, still need to fasten the brackets onto the panels and secure the amp. I went with a 10" JBL in the back with a seperate box, which does well.
I purchased some Rockford Fosgate speakers in the front and they fit right in, with no mods. They were the thinest I could find! Never have seen a reverse cone speaker like the stock front speakers. Toyota engineering at their finest!
Amazinging what a little fresh sound will do to the 80's!!
Thanks for the informative post!!!
Later-
D
Absolutely wonderful post.
Now, I must beat you. :flipoff2:
Thanks!
Nice install. Have you considered airbrushing the speaker grills for a clean, OEM look?
Impressive Stress nicely done. :cheers:
YngTLCOwnerHow much did you end up spending for the complete set up? Also said:
Isn't that like asking a woman her age? ;) I haven't added it up to get actual amounts (so I can truly tell my wife I don't know how much I spent!!!), but I think it was in the $1100 range. I bought the amp on eBay, and the rest of the stuff from www.woofersetc.com.
As for speaker wire, I had some 14 guage 4 wire Monster Cable used for home stereos (in wall). I ran one lead from the amp to the drivers side rear door (up the right side, under the dash, down the left side). I split the wires at the kick panel and put to into the front door and ran the other two back to the back door. Did the same for the passenger side, but split at the pillar and ran two into rear door and two up to the front door. I used 10 guage or so for the sub-woofer.
Thanks!! And yes, I have done this before. I hate to admit it, but in my early 20s, it was not uncommon for me to have a car with a stereo worth more than the car. Gotta have good tunes, right?!?!?! I had an install place do one for me, and being very anal, I didn't like it so I pulled out the entire interior (seats and all) and re-did it to my liking. That was a waste of time and money, but a good learning experience. But I wouldn't put myself in the category with the "pros" out there, like the shop that did Brentbba's rig. "I'm not an installer, I just play one on TV!"
Yes, but if I decide to do it, it will wait a bit. I want to enjoy things before pulling into the door panels again!!!!
Nice job! Didn't realize you were that far along. I'm going to have to come hear that system pretty soon.
Stress, VERY nice job man! That's just how i want mine, minus the sub box in the back. I might go with a smaller amp and put a sub in the stock location in the rear panel, maybe cut it to have a larger one though.
Big thanks on posting the pics of your doors with the dynamat! Gotta love the dynamat. I was pondering on how to place the dynamat, either behind the plastic, or on-top of the plastic on the door panels. Looks like you did both. A little behind and a little on-top. Are you worried about the dynamat getting moisture on/in it and mildewing or smelling moldy? Did you actually pull the plastic off, place the dynamat, and then stick the plastic to the dynamat?
So many questions.........thanks man.
Excellent install and write-up. I particularly like the way the rear speakers turned out, very resourceful. I managed to get my eclipses installed behind the factory grills, but they're 5 1/4s up front and 4"s in the back. I also am just running off the factory amp. My plan is to install an 8" sub in the stock sub location and power it with a 250-watt Memphis that I already have.
Concrete, I believe dynamat is a synthetic product(from my understanding it's like an immensly dense bubblewrap) and doesn't really have anything for mold to grow in, but I could be wrong.
:cheers:
Ary
ary, yes i know, i have some installed in my truck at the moment. But it is currently placed across the front floor-boards and over the center console, and over the rear wheel-wells for noise, temperature and heat. But where it is now there is no way it's going to get wet. I was thinking that when placing it, there are seems, creases and little areas in which water could hide.
ah, ok, I've never touched the stuff, just read about it online. My uncle and I have been debating sound proofing materials as I wanna do my cruiser and he wants to do his 'vette. We decided that I would be the guinea pig since the cruiser is a lot more spacious and easier to work on, and we would split the cost of any wasted materials in the testing process. I think we're gonna try peal and seal, water-heater insulation and dynamat extreme and see what works the best for the $$.
Ary
