Hi everyone, new here. Just purchased a 2013 LX 570 with 98k miles. I was looking at 2011s so I paid more than I wanted to, but I do love the thing especially with the adaptive cruise and digital speedo (didn't even realize the 2013 had it, thought it was 2014+, only noticed on the drive home with it, pleasant surprise)
I tried my best to see as much as I could before buying it, tested the AHC and got under it and was really mostly looking for rust. Thankfully it seems legitimiately 100% spotless in terms of rust, not even a spot of surface rust as far as I can tell. Carfax showed it as being owned in very very south Texas its whole life until coming up here to the PNW a couple months ago. It also had plenty of Toyota dealer services done throughout its life, which brings me to my surprise after I got it home and really started digging a bit deeper and started noticing quite a number of what ill call "oversights". Thankfully so far it doesnt seem like anything major that I can't fix myself. I added photographs as best as I could to show what im working with. Seems like the forum has a 5 image limit so I provided and Imgur link.
To begin, there is a mysterious hose that is not connected, located roughly above the driver side axle. It appears the rubber hose should connect to the metal tubing, but it does not. I can't figure out where the hose goes, but if you follow the metal tubing it eventually terminates into the upper wheel well, where another tube is connected but then just ends about a foot later with a wobbly metal tip on it. Any clue?
Secondly, there was quite a substantial amount of grease located on and all over around the front passenger side CV Axle boot. I cleaned it up the best I could with a whole lot of degrease and shop towels, so the picture looks somewhat decent, but it was quite bad and just a gunky mess all over the area. However I cannot seem to find any evidence of a tear or leak in the boot, I drove a bit earlier after cleaning it to see if it would leak more but I dont see anything new. I'm not sure how to tell if there is still enough grease inside the boot or not, but when comparing how it "feels" when pressed on with my hand in comparision to the driver side (which looks totally clean), they both feel about the same. I also don't hear or feel any werid rattling or odd noises when driving. Maybe it was replaced before and they never bothered to clean it up?
Thirdly, I took it home with the "Low wiper fluid" warning on, thinking you know, it just needed fluid. Well turns out it needed fluid because the connection from the tubing to the driver side headlamp washer assembly was steadily leaking fluid after i topped it off. It seems like someone attempted to seal it with what appears to be electrical tape? Dunno. Well after digging into it, it seems it is missing the washer hose joint (Part # 85279-33050, please correct me if im wrong since there appears to be several simmilar parts), so for the time being i just disconnected the hose and zip tie "clamped" it. Hopefully that part works.
Fourthly, kinda in general it seems like whoever worked on it, which from the service history makes me think it was the toyota dealer, just seemed to do a really half @ss'ed job on a lot of panels and brackets and such. The engine bay panels are missing all the clips except for one per panel (easy fix i already got replacements). And the unbody and grille and fender components are all missing weird assortments of bolts/screws/clips, so a handful of albeit superficial components are just kinda hanging loose and dangling around. It feels weird to walk up to a $100k + vehicle (new of course) and have to love tap the grille and panels back into place. Also, it appears to just be straight up missing the front underbody skid plates/panels, the middle one is attached but just kinda half dangling since it seems like its supposed to attach to the front ones that are missing.
I hope i didn't get suckered into the seemlingly good service history and lack of rust and end up with a problem child. But so far it at least seems these are easy/cheapish fixes and otherwise it is mechnically sound. Also the interior is in great shape and everything seems to work. Overall I still absolutely love the 200 series and have planning to get one for many years, it really is an amazing vehicle. Any help with these "quirks" are appreciated. Thanks guys.
