Feed up with your crappy 80 series battery mount? We have a fix
1924274
Installed mine today. New battery needed a new bracket. With the help of an Optima Group 34 spacer, the bracket mounted up fast. Did not receive a template for drilling holes for the new brackets, but I just drilled where I thought they should go. Worked out fine I guess. Thanks for the 2 lifesavers as well
View attachment 1924274Installed mine today. New battery needed a new bracket. With the help of an Optima Group 34 spacer, the bracket mounted up fast. Did not receive a template for drilling holes for the new brackets, but I just drilled where I thought they should go. Worked out fine I guess. Thanks for the 2 lifesavers as well
Should be fine but you can always re-drill
TO ALL - The PDF template is on our website where you ordered at. Download the PDF and THEN print it for best accuracy.
PDF attached here
