Fan Bracket Incompatible
Mag
Plover, WI
I am replacing the timing belt and water pump on my 2007 GX470. I bought a new Aisin fan bracket from RockAuto to install since that part is buried under many of the items I need to remove for the timing belt job. As I exposed the fan brack it was obvious the Aisin fan bracket from RockAuto was not even close to matching the existing one. As I search the internet I realize the style they sent me is commonly shown as the correct part. I did find a seller on Ebay with one that matches for over twice the price. Have any of you encountered this? If so, where did you go to get the correct part?
I bought one for my 05 from Rockauto and they look identical. Cost me around $100. Can you share the pictures? Not quite understand the difference you are talking about.
It may be an illusion. When I get the old one off I can compare them better than when it is on the engine.
I was incorrect. Once I could see the entire bracket I realized it was the correct part from Rockauto. Sorry for the confusion.
