Falken 285/70R18 AT4 Load Range C (1 Viewer)
I just put on this tire in the 285/75/17, which is a similar overall size. I also got load range c. So far so good
I just noticed DT is listing the Falken Wildpeak A/T4 in size LT287/70R18 in Load Range C as coming soon!
This will be only tire in this size in LR C that I know of. Still a heavy tire at ~68lbs, but probably a much better ride than E’s with 10 plys.
I’m about to replace my 3’s with the C 285/70 18’s. Did you end up going with these tires and if you did how do they fit. I’m only running the OEM front spacer. TIA
That’s really heavy for a C rated tire…. What’s the point
I’m not sure I have one
An honest man. I just think if it’s the same weight as an E, go for the extra protection of an E. I understand it it’s oighter
The Toyo AT3 is a super lightweight AT
Never tried, I’ve since sold my LC and bought a Raptor. Now 37’s with ease!
The amount of lift won’t help much. They will rub stock UCAs and KDSS arms, besides the obvious plastics. The wheel needs to be pushed out ~1” to move it away from those to clear with minimal rubbing.
I’ve been running 285/70r18s for six months. I’ve been able to get it to work with my SPC UCAs and a good alignment.
