Factorystylewheels.com "FSW" Toyota TRD Pro Style wheels for Land Cruiser 200 (1 Viewer)
Delaware
I was asked by a few forum members about the wheels I installed on my LC. I recently contacted the company to ask for some details and received an immediate response. I originally searched for a set of the 18" TRD Pro BBS Forged rims because I wanted a factory spect wheel and loved the look, however the prices were still too high. Some members referred to the wheels I choose as "Ebay junk". I have listed a few details about the wheels since there isn't much listed a few photographs of them mounted on Land Cruisers. For those who do not know I installed 285/55R20" BFG K02's 43 lbs psi. FSW allowed me to purchase a 5th Satin Black wheel and it fits under the vehicle with no modifications. I have had zero issues with rubbing. The last photo was taken after I added OEM strut spacers that added approximately 1" to the front.
Safety standards: Wheel Safety Standards
Wheels have the JWL, VIA and SAE indication stamps on the wheels
Off Road Pro Style:
Diameter: 20"
Width: 9"
Offset: +20
Bolt Pattern: 5x150
Center Bore: 110
Back Spacing: 5.75
Construction: 1-piece cast
Material: Alloy
Weight: 32.80 lbs.
Load Capacity: 2500 lbs
Curious how you went from the 18” TRD wheel to these at 20”.
Off Road Pro Style:
Diameter: 20"
Width: 9"
Offset: +20
Bolt Pattern: 5x150
Center Bore: 110
Back Spacing: 5.75
Material: Alloy
Weight: 32.80 lbs.
Looks great.
Looks nice, admittedly not a fan of short sidewalls on all terrains, but that is a good combo.
The depth looks far better than the bbs wheel. What is the width and offset compared to the 18” BBS?
Thanks guys. I couldn’t tell you the offset of the BBS’s but they are 18x8 and don’t fill out the wheel well the same as mine. Some guys are using wheel spacers to push them out which I refuse to do, plus I am not a fan of the gloss black rims. Admittedly I would prefer the taller sidewalk that you get with an 18” rim but I am not going off road and beating it up on the Rubicon trial. It is my daily driver and I plan leaving the suspension stock. It drives great and the lower profile feels right for the road imo.
Genuine BBS TRD Pro wheels +60
08-15 landcruiser +60 (unsure about LX)
16+ landcruiser +56
Off Road Pro Style:
Diameter: 20"
Width: 9"
Offset: +20
Bolt Pattern: 5x150
Center Bore: 110
Back Spacing: 5.75
Material: Alloy
Weight: 32.80 lbs.
Those look great dude.
16+ landcruiser +56
You said you refused to install wheel spacers but installed strut spacers in the front. I do not know the difference really. Why ok on one and not the other?
Totally different part in a totally different application. Strut spacers are in compression, and in the case of the OEM style Strut spacer even a total failure would at worst cause an uneven stance, but not a catastrophic failure. Wheel spacers are in shear, and a failure of a wheel spacer, and the wheel comes off. I've used both, and if properly torqued and inspected at some frequency, high quality wheel spacers can be used safely. That said, I understand why folks may chose to use strut spacers but not wheel spacers.
I'll try to explain.. but basically they are fundamentally different when you look at how forces are applied and the possible ways they can fail.
A strut spacer is simply a shim that sits between the strut/spring top and spring bucket/perch in the frame. In my case it is 10mm, which is short enough to still use the original studs in the spring seat, going through the spacer then into the perch as stock, with plenty of bolt still through the nut. These spacers sit in compression only, meaning it is just a chunk of metal getting squished all the time. For this to fail you'd have to put EXTREME forces on the truck.. ones that would make many other things fail first. A more likely issue with this setup is the top of the strut moving downward 10mm but no adjustment to the bump stops which act on the lower suspension arm. If that 10mm is enough to let the strut bottom before bump stop contact you could damage the internals of the strut, but as far as I can tell this isn't an issue. Toyota seems to have designed enough travel into the strut to allow for the 10mm different mounting position.
Contrast that with wheel spacers. As stock the wheel studs are designed to thread into the lug nuts a certain amount. These are blind lugs where the stud goes into the nut, but not all the way through. Good engineering practices mandate that there is more thread engagement than is actually necessary, so in theory you could run a thin spacer and reduce thread engagement, but you are eating into your engineered overhead, and it would take.. an engineer.. to determine how much is ok before you start compromising the strength of things. Plus you can run into concentricity issues when a weel is hub-centric, leading to a wobble. All of this is on top of the fact that a spacer moves the wheel outward and as a result puts more force/leverage on the hub mounting face. So in effect you are changing the forces the system sees, and one could make an argument that you should want MORE thread engagement in that case. And this is if the hub is ok with the forces, which apparently they are. Toyotas in general and landcruisers in specific are over-built.
That's a thin spacer. Most people running spacers are actually 1"+. Suddenly there isn't anywhere near enough stock stud to move the wheel out and have a lug thread on, so the thicker ones bolt to the hub face and stock studs with their own lug nuts, then have a second set of studs anchored in the spacer that your wheel bolts up to. You are drastically changing the forces involved (unless you use a wheel with an offset that keeps the tread in the same place in relation to the vehicle), doubling the number of lugs that can work loose, increasing the likelihood of concentricity issues, hoping the spacer manufacturer uses the same standards toyota does for stud strength and mounting.. basically it changes forces a lot and adds a ton of variables. As for what's different with a strut spacer.. your wheels bolting to the spacer itself, no longer the hub, and the spacers are not just in compression. They are also in tension, and shear and all kinds of other dynamic forces are applied.
I've written before about how I'm impressed by toyota's engineering of these vehicles and like thinking through why they designed things the way they did. I put a lot of faith in their ability to know what they were doing, and personally wheel spacers seem like too big of a departure from the design parameters they used, so I won't be running them.. I'll use a wheel that has the correct offset, load rating, size, and weight to get the job done without having to put what I consider band-aids on a problem. And by the way no offense to the people that choose to run spacers.. many of them are quite smart and know what they are doing. I just choose not to.
Edit: and if pictures help I can find some.. but it'll take me a while as I'll be busy for a few hours.
bloc, thanks for the physics lesson on spacers!
Could also add that quality wheel spacers are not cheap and that is going to add to your total cost when buying those factory BBS rims if you even decide to go that route. Main reason I choose a wider wheel with a more aggressive offset was because I didn't much care for the look of the factory wheels and how they are pushed inward. The OEM wheels are more practical and engineered that way for reason I am sure.
It all comes down to personal opinion. The new SUV trend these days are big wheels. 20" seems to be the standard now days. The LC is a different animal and used by many unlike any other large SUV in the world. Totally understand why the enthusiasts are running 17" and 18" wheels with larger diameter tires...they work better off road. I prefer more of a car feel on the road so I pulled the trigger and went with 20's. I have plans to install a 2" lift kit in the near future. Trend on this forum seems to favor the OME BP-51 set up. I will probably go with the package along with SPC brand UPC's to allow for correct alignment.
Search post for Tundra wheels / TRD Pro BBS Forged wheels. You will see that several guys are adding spacers to push them out and IMO it looks much better. Post up some photos of your build so we can see what you chose.
BillyG-
Your truck looks great. I'm in Kennett, but work in Delaware. Who works on your LC?
My local mechanic is Penny Hill Auto Service Center on Philadelphia Pike, Wilmington. Shop # 302-765-3950. Garage owner is "Brian". They are awesome. He told me he is buying my truck when I sell it! Lol They can pretty much do anything you need done. He races mustangs up and down the East coast and has been pretty successful.
Pricing is great and work is top notch. They love working on cars and trucks for people who are passionate about their ride.
I could also recommend Bear Alignment on Scott Street behind the 7-11. Jim the owner has been there for ever and I would trust him to do any and all suspension work . Only problem with Bear Alignment is that he is a one man operation and you generally have to get on the list because he is so busy.
Thank you
Any time. And you bring up a good point.. if you are going to run spacers that is an absolutely critical part and one of the last places someone should try to save money.
As for why toyota has the wheels inset.. it is to clear body during full suspension and steering travel plus any bushing compliance during big bumps, as well as contain any mud that gets thrown off to the wheel well and not the side of the vehicle. I’ve run trucks with wide tires and lots of offset before on muddy trips and the mud ended up everywhere. My 200 with rock warriors keeps almost all of it under the truck and some on the sliders. I can live with that.
FWIW rock warriors are 10mm different offset which helps some already, and 17” wheels allow for more sidewall, which bulges more, and both of these add up to making the tire appear to fill the fender well much better. It doesn’t come across well in pictures but in person it’s a noticeable difference.
Obviously not the case with 20s, but as you said people have different goals.
Off Road Pro Style:
Diameter: 20"
Width: 9"
Offset: +20
Bolt Pattern: 5x150
Center Bore: 110
Back Spacing: 5.75
Material: Alloy
Weight: 32.80 lbs.
Looks great! Going to try this wheel tire setup on my LX570!
Thanks, If you can I would go with a 285/60r20. I was told that 55 was the size that fit with no problem but of course they were being conservative. The larger tire would fit and give you a little more sidewall. I only put about 1,500 miles on that set up and switched over to the 17" Rock Warrior wheels for winter. I haven't switched back yet. If you never plan on really doing any off road driving there is nothing wrong with 20's for the street. I just think that my 20" wheel look more aggressive pushed out. The RW's are sucked and I really don't want to run spacers.
Looks super!
Thank you for this!! I have been taking in all the glorious information this forum has to offer. I imported a 2001 LC Cygnus from Japan and it came with 24 inch 2Crave wheels. Thanks to this thread, I have finally found wheels to replace the monstrosity that is ruining my ride.
