Factory CD player (1 Viewer)
up on the MTN.in California
Does anyone know how to get a stuck CD out of the player? It's a '93 FZ80. I tried to use a tweezers, but that doesn't work. :confused:
Hatman,
There is a reset button on the headunit (I think near the tape deck area) it's a very little sunken button. If you push that and hold it should cause the cd to spit out. Good luck
-Sam-
Not exactly sure where yours is, but I think all CD player have them...it's a small switch just inside the bezel where you insert the disk. It's usually just to one side or the other of the opening, and you can poke around with a straightened paper clip or something similar. I've done this on several CD players without failure.
Thanks, guys! But it still won't pop out. The cassette player still works. I guess I'll have to dig out the old cassettes.
This must be a common problem with the cruiser's CD players. mine had a stuck CD from the prior owner and could never get it out. Today after reading this thread I went and look for the mentioned reset button and could not find it, so I used the "forza bruta" approach and yanked the stucked CD out with a pair of narrow needle nose pliers and after some persuation it came out, but now I am not sure if I can put another CD in and have not getting stuck.
Is there a way to find out why these CD gets stuck? A fix anyone? Please?
