Dunbar
I just upgraded to a Mean Green Alternator on my FJ62 and have had Urban Land Cruisers dual battery wiring kit and 2 group 65 Sears Die Hard Platinum batteries.
The MG alt I think puts out 130 Amp. My dual batt kit came with a Sure Power 95 Amp isolator. I think it has failed so I have purchased a 120 Amp isolator to replace it.
I want to run another wire (1AWG) from the alternator to the primary battery. Currently with Dearborn's kit there is a 4AWG wire from the alternator to the A pole on the isolator. Then there are 4AWG wires from the #1 and #2 posts to the batteries. The wire to the primary battery, #1, goes into the stock wiring harness that has 2 wimpy 10AWG or so wires in it that go to the battery. The wire to the secondary battery is 4AWG and goes through a 50Amp circuit breaker.
Do I run the 1AWG direct from the alternator to the primary battery or come from the #1 pole on the isolator to the primary battery? Either way it will go to a ANG 200Watt fuse close to the battery.
This thread, "Maximizing the performance of the stock alternator"
has good info on adding the extra wire. On my Powerstroke Excursion I have a 270 Amp alternator with a 00 wire with a 300 amp fuse. But it's 2 batteries are not isolated. I left the stock wire from the alt to battery in place there as well.
on the FJ62 if I go directly from the MG alt to the primary battery, will I defeat the purpose of the isolator? I would think that the isolator will tell the alternator via the exciter wire when to charge the batteries. Or do I need to go from the #1 post on the isolator to the primary battery?
Thanks,
Dunbar
Thanks,
Dunbar
